-----Anodize parts being tacky
What would cause parts to have a tacky feeling after they were supposedly dried and what would cause the powdery residual after they have been anodize. Metals predominate used are 2024-T3, T4, and T351; 7075 T6 ; 6061 T6
Cindy CarrascoQuality Control Inspector - Kingston, Washington, USA
August 19, 2008
August 19, 2008
Hi, Cindy. Probably poor sealing. It's a common theme: Letters
26372,
34094, and
6811 have interesting discussions on this, and you can find still more with the search engine. Good luck.
Cindy
To take Ted's response a step further, some anodize coatings are required/specified to be sealed, while others are required/specified to be unsealed. Properly sealed coatings will not exhibit the stickiness you mention, while unsealed or inadequately sealed coatings will. A sticky coating does not necessarily mean poor sealing.
- Colorado Springs, Colorado
August 20, 2008
