Copper-Nickel co-plating
I'd like to co-plate copper nickel using a single plating bath. Where can I find information on co-plating these metals and controlling the composition ratio?
Plating user - Boston, Massachusetts
August 4, 2008
August 5, 2008
Hi, Yyes, If you study the Nernst equation you will marvel that it is possible to plate any alloy at all. There are a number of plateable alloys but I am not aware of plateable copper-nickel alloys. Hopefully someone else will be.
Safranek's book Properties of Electrodeposited Metals and Alloys
[affil link to
on AbeBooks (adv.)] lists references for nickel from 8% to 56% nickel, balance copper. These look like Russian authors, but are in English speaking publications. They are all from a pyrophosphate bath. Will it work? That is debatable. You can always buy the referenced Publications or copies of the articles and try it out in a lab sized trial.
It is very probably going to be tough to control. It certainly is not in commercial operation in the USA.
