Are galvanized zinc coatings okay for transformer oil?
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. What are the reasons for getting green colour transformer oil in storage drums?
Lakshmi .gEmployee - Hyderabad, India
May 4, 2022
Q. WE ARE A TRANSFORMER MANUFACTURER IN INDIA. THE CONTAINERS ARE GALVANIZED ON THE INSIDE. DOES IT HAVE ANY EFFECT ON TRANSFORMER OIL WHEN IT IS IN CONTACT WITH ZINC? DOES INSIDE SURFACE WITH ZINC/ GALVANIZING REQUIRE ANY PAINT TO AVOID ANY EFFECT ON TRANSFORMER OIL?
JAYAPRAKASH RAO- Hyderabad, A.P. , India
July 29, 2008
August 1, 2008
A. You are fortunate in that transformer oil must be dry (low water content) to retain its insulating properties. Moisture in oil is the reason that any reaction takes place in this type of situation. But in a transformer, moisture in the oil causes arcing, a much bigger problem that slow corrosion.
Zinc does not dissolve in or react with most mineral oils.
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
A. In certain conditions zinc may create a zinc metalo-organic compound . I would go for a test piece ,immersion in oil for couple of days or weeks and to weigh before and after, checking any weight loss.
Khair Shishani
August 12, 2008
