Black anodize won't pass seal testing
I NEED SOME HELP IN SOLVING MY PROBLEM, WE ARE HAVING A BIG PROBLEM WITH PASSING A SEAL TEST FOR COLOR ANODIZING. DOES THE TEMP OF THE SEAL BATH NEED TO BE OVER 160 DEGRESS? THANKS FOR ANY HELP YOU CAN GIVE LYNN
LYNN MILLS
OWN A METAL FINISHING BUSINESS - COLUMBUS, OHIO, USA
July 29, 2008
The seal we use has a temp spec of 165-205. We run it around 190° and have been doing fine on seal tests. Check with your supplier for correct temps for the product you are using.
Mike Davis
- Kalispell, MT
September 2, 2008
