49063
Electro polishing for weld clean-up
June 17, 2008
We do in-house TIG welding on 304 SS, basically to join a 3/4" or
5/8" shaft with clevis which has various OD ranging from .71" to
1.25".
After welding the dis-coloration need to be removed and we use
electropolishing, which works great for welded with low power input
while on higher power input weldings the clean up is not
acceptable.
Does any one has any idea what went wrong or better means of removing
the dis-coloration?
Thanks a lot.
Keffelew Assefa
- Vancouver, BC, Canada
