49059
Electro plating on exposed steel
June 18, 2008
Hi,
I have an steel bracket for which an electro plating has been done as
coating. I would like to know, for an exposed steel , how much is the
min thickness of electro plating is required. Currently, an 20-25
micron thickness of electro plating has been done. can anybody advise
me on this.
regards,
Sri Srilakshmi
structural engineer - Bangalore, India
June 18, 2008
Hi, Sri. Sorry, I don't understand. What metal is the steel plated
with and why? This is a very substantial thickness if it's zinc
plated but a minimal thickness for nickel plating. Are you sure it's
electroplated rather than hot dip galvanized? If you are speaking of
structural use outside, such as a bridge component, this thickness
doesn't sound like much.
finishing.com
Brick, New Jersey
