49040
Problems with chromium bath
[Colombia]
June 16, 2008
Hello, I'm Carolina Alvarado I'm a student of Chemical
Engineering, actually I'm working in my Thesis topic and it's about
electroplating on ABS, in my country Colombia this process may be is
a little backward respect the world industry, but I hope that change.
In the plant where I work we have a problem with Chromium bath,
because we want give more time in the bath but is imposible, because
the pieces tend to burn, actually the bath conditions are:
Chromic acid: 250 g/l
Sulfate: 3 g/l
Temperature: 35 -45 ºC
Time: 1 min
Current density:5 – 30 Amp/dm2 (depend de catode surface)
could you help us please we don't know what is the problem...
Carolina Alvarado
student - Bogotá
June 18, 2008
Pieces burn because they are being run at too high a current
density, not because of the time in the tank.
We are also using chromium bath in our ABS plating process, the
failure of chromium bath can be easily seen from the hull cell test..
we always use this test to see the bath condition.. and generally te
amount of the H2SO4 in the bath cause problems then we add BaCO3 to
our bath. Also the amper that u use is seeming too much to me..
regards ..
Eren Sakar
- Izmir, Turkey
