49031
Crack in deep drawn components after pre
treatment
June 13, 2008
Deep draw components made from CRCA 1mm thick about 5" OD and 7"
height. CO2 Welding done on the outer surface, crack found after
phosphating.what is the cause for this? material or drawn process or
pre treatment process
Senthilkumar Ramasamy
material incharge - Chennai, Tamilnadu, India
June 13, 2008
Hi, Senthil. Phosphatizing does offer some potential for
hydrogen embrittlement but I believe it's usually considered minor.
Was one part cracked or all 50,000 of them? Iron phosphate ot Zinc
phosphate? What is the hardness of the components? Thanks.
finishing.com
Brick, New Jersey
June 16, 2008
What is CO2 welding?? That is a new one on me.
Welding is not amenable to deep drawing, or at least there would be
problems on some if not all parts.
My thought is that anything that is deep drawn had to be fairly soft
to start with. It is possible that it work hardened in the process
and a stress relieve cycle may be needed. Normally it would be done
at the end, but it may be needed before the start or in the middle of
the steps if that were practical.
