Color of CED paintJune 12, 2008 Why generally OEM instries using Black or Grey CED paint? If we are using red or blue CED paint then what kind of problem create in regular painting process? Bhavesh. Joshi
July 2, 2008 Absolutely no problem if you develope the CED paint color may be
blue or red with your Paint supplier. How ever there are seperate
stages for CED , UF1 , UF2 & DM rinse stages are required. P.M.Saravanan
July 19, 2008 CED coating and its development has been intertwined with the
automotive component surface finishing requirement. The requirement
here has been a primer coating in black or gray. And only for this
reason, in India particularly, only these two colours are available.
Outside India, where there is sufficient demand CED coating is also
available in different colors.
Save
