49014
Vegetative Growth in Acid Copper
June 11, 2008
Hi,
I was hoping to get some advice about an unexpected result from a
sample I grew in an acid copper bath. I'm trying to encourage treeing
deposits in an acid copper bath, with an eye to making a sculpture
employing this phenomenon. I've been trying various combinations of
sulfuric acid, copper sulfate, proprietary levelers and brighteners
and adjustments in current density to get a range of different
aggregations. I've made a number of different samples, using phos.
copper sheets cut into strips as anodes, and plating onto a thin
strip of the same material over long durations in a small bucket bath
with some aquarium air pumps providing agitation. I had one real
stand out from the spectrum of deposition behavior I've seen and I
think this is because the bath became contaminated. I find the sample
very attractive and would like to reproduce the result but I've tried
reformulating the bath and have gotten a very different result,
probably because of the absence of the contaminant.
Can anyone help me determine what this contaminant might be, or
suggest another contaminant that might achieve the effect seen in the
sample?
Some information about the 1 gal bath: 18 oz/gal CUSO4, 6 oz/gal
H2SO4, 0.6 ml HCl, small concentrations of brightener and leveler.
Agitation via air pump. Phos-copper anode. 72 hours of plating at 2V
about 1 A. Some curious things that happened over the plating run:
solution went from clear blue to an opaque green cast, and was
leaving a yellow-ochre scum where it contacted the poly-pro bucket,
when the solution was later filtered through coffee filter the sludge
was a similar ochre color (unlike the typical copper/brown sludge
I've encountered.) In the image of the sample, notice the rainbow
iridescent ringing at the central bar. I think this points to an
organic contaminant, could this be the Bon-Ami I've been using to
clean copper with? Any suggestions of a contaminant that might
encourage this vegetative-like growth?
John Berseth
Hobbyist - Doylestown, PA, USA
Ed. note-- Readers, who are experiencing a feeling of deja vu may
wish to know that John has been working on somewhat similar projects
for some time now, and has previously contributed Letters
45277 and
46603.
July 29, 2008
Was your solution open to air?
Is there any proteins or other things in the solution that would
support any plant or bacteria?
I'm thinking either a yeast or algae may be responsible.
Allow me to expound a bit further, I've read recently that the EPA is
doing some uranium contamination cleanup work by using bacteria to
nibble off electrons from the uranium 7 and get it down to
non-reactive uranium 3.
Do you think it would be possible you accidentally did something
similar? It would probably be informative to put your sample under a
microscope and see if there is any cellular pattern or any other
trace of an organism at work. If not it would at least help you trace
how this spread out.
Marc Banks
Blacksmith - Melbourne, FL
