49009
Chrome Bath Help: Chrome to Acid Ratio
June 10, 2008
I have a Baume of 28 at room temp. Is this right? Does sulfuric
acid raise or lower the Baume reading.
My chrome is depositing gray. I'm new and have the books coming but
I'm excited to see it work.
Please be gentle with me, I want to learn.
Brian Morgan
New Operator - Arkansas, USA
First of three simultaneous responses -- June 12, 2008
Hey there,
well, with 28°Bé you have approx 345g/l CrO3 containing
in your bath. If you are using a conventional chrome plating bath,
than the ratio between sulfuric acid and chromic acid should be max.
1% (3.4g/l Sulfuric acid). Remember, sulfuric acid is your primary
catalysator for your chrome process. On the market some other
additives avalaible which increases hardness, appearance, throwing
power and efficiency.
You have describted a grey deposit, so you should check at least your
sulfuric acid content via centrifugal method and adjust if
necessary.
The density of the electrolyte can also be influenced by metalic
contaminations.
Dominik Michalek
- Mexico City
Second of three simultaneous responses -- June 12, 2008
Baume is a poor estimate of the condition of the chrome bath. For
good and consistent results,you need to do a titration for the chrome
and analyze the sulfate with a precipitation and centrifuge method
which is quick easy and reliable. Kocour makes an hand powered
centrifuge that is OK, if you maintain a constant and correct
RPM.
Baume measures everything and it all contributes to a higher reading.
Chrome, acid, trash and etc.
Third of three simultaneous responses -- June 12, 2008
Brian,
First I should have thought you would have read the book before
starting. Second, I hope you are an industrial user who is
knowledgeable in the handling of these hazardous materials and in the
disposal thereof. If not STOP NOW. You may be getting yourself ready
for a lot of time spent in litigation over waste, storage, use and
safety regulations.
The correct ratio of chrome to sulfate (not acid, but the sulfuric
acid contributes the majority of the sulfate) depends on whether you
are running a non proprietery or a porprietary bath. The proprietary
bath with have technical data which will tell you what ratio is
suited for that chemistry.
The Baume (Be) is giving you an idea of the total disolved solids in
the bath. By using a chart, an estimate of the amount of chromium or
chromic acid can be arrived at. One then determines the sulfate by
analysis and calculates the ratio and makes additions accordingly.
Gene Packman
- Great Neck, NY
June 16, 2008
Brian,hello.
Sorry, I got more questions than answers. Apart from chromic acid and
sulfuric acid content,
1. What is the operating temperature?
2. What is the current density applied ?
3. What is the plating time?
4. Hard Chrome/Decorative chrome?
5. Substrate ? Chrome applied over Nickel?
SK Cheah
- Penang, Malaysia
June 16, 2008
SK,
They are all interdependent for a quality coating. Personally, I
would buy two of the recommended books from amazon or whoever has
used books in your country. Read them cover to cover before you spend
a single rupee on anything else. There is a massive amount of
information and sorting it all out is not simple as every plater has
a tweak or two on one of the two or three main process methods.
Chrome plating is as much an art as a science, so consider working
for a chrome plater for a year before jumping into the business.
Chromium used for decorative purposes is 0.16-0.2 microns. At
higher thickness the chromium will crack severely. gold is relatively
soft so the cracking may be visible at 0.5 microns. I guess this is a
decorative application not practiced in the US to my knowledge. The
optimum chromium to sulfate is 100:1
