Compatibility of Rodine with Plastic & Resin
Q. We are thinking to prepare an acid solution in a truck (used to transport HCl) with HCl and inhibitor Rodine. I would like to know if Rodine can affect the internal covering made of Plastic+fiberglass and resin Derakeni (CatBO411)?
Roberto Villarroel
Chemical Eng. - LA /Brazil
April 29, 2008
A. Hello,
I don't know why are adding Rodine (see note) to the HCl if your Truck Tank is already coated with plastic.
Rodine should be used for parts being immersed into HCl solution.
Either way, Rodine wouldn't attack (in the case) your Resin (alcohol is about 12% diluted).
NOTE: Rodine => http://www.telfordindustries.com.au/Uploads/Images/Rodine%20213.pdf
Jose Castellanos
- Minneapolis, Minnesota, USA
Ed. note Oct. 2022: That URL no longer works, but Henkel should be able to point you to a similar paper.
