Colorfastness Issues with Red Anodized Aluminum Flashlight Bodies
April 20, 2008
I am dealing with my first issue dealing with anodized parts. I have an anodized aluminum flashlight body that is failing the colorfastness test required by one of our large customers. The sub-contractor(s) that I am using for my parts both seem unable to indentify the root cause of the problem, so I am attempting to reseach and find the soultion myself.
Questions:
1. My customer is requiring that the anodized surface maintain a rating of 3.0 after 100 hrs exposure to a Xenon Arc Lamp, per the AATTC requirements. My parts are testing at between 1.5 - 2.0 at the current time. What are the most influential factors that I should begin to look at?
2. How do I confirm the type of anodizing that my subcontracctor is using?
3. Which type of dye is most suitable?
4. Are certain colors more likely to fade than others?
5. Can I have a chemical analysis performed to find the root cause of the issue that I am experiencing?
6. Can additives be introduced into the dye to increase the colors ability to better withstand UV exposure?
7. How can I confirm the quality and integrity of the sealing process after the dye has been applied?
Jim Moore
Product Designer- Las Vegas, Nevada, USA
First let's do an ASTM Seal test. Some reds are very difficult to seal. Many job shps do not even begin to control their seal.
robert probert
probertbanner
April 22, 2008
