Effect of sulfur oixide on MIL-C-5541, class 3 conversion coating
Our company manufactures electro-mechanical connectors.
One of our products is made with aluminum alloy 6061-T6 and coated with MIL-C-5541 chem film, class 3.
How does sulfur dioxide in the air affect aluminum parts coated with MIL-C-5541 conversion coating, class 3?
Concentration of sulfur dioxide in the air is unknown.
Laban Young
QA Engineer - Irvine, California, USA
April 1, 2008
Hi, Laban. I probably don't understand the context. You can't design for unknown and untested exposure conditions. But you can have your parts tested in a sulfur dioxide accelerated salt spray chamber if that helps. Good luck.
April 2, 2008
SO2 + H2O = H2SO3, while not the same as H2SO4, it is an acid and will attack the chem film and the aluminum, especially the alloy ingredients like copper.
April 7, 2008
Mil-C-5541 describes chromate conversion coatings for aluminum. An accelerated corrosion test that uses Sulfur Dioxide as one of the corrosive agents is the Kesternich Test ( DIN 50018, ISO 3231 or ASTM ASTM G87 ). In my personal (somewhat) limited experience, chromate conversion coatings do not improve the corrosion resistance of zinc coatings in this test. I would assume that the reason for this is that the sulfur dioxide is a strong enough reducing agent to reduce the hexavalent chromium to the trivalent form, which is non-inhibitive, and also strong enough to prevent the oxidation of the trivalent chromium. (I would be interested to know if others have seen this same phenomenon.) I'm just passing along what I understand the chemistry to be. You can draw your own conclusions.
tom_rochester
Tom Rochester
CTO - Jackson, Michigan, USA
