Sealing leaky rivets in aluminum boat
Hi my name is Tim and I have a 1959 alumacraft 15.5 ft. that is leaking pretty bad at the rivets. What would be the best way to repair this problem before I paint it.
Tim Heath
hobbyist - Deland, Florida
March 22, 2008
Assuming the aluminum sheet under the rivets isn't badly corroded, the best fix is probably to replace the rivets with new ones, possibly with a tiny bit if silicon sealant under each. Lots of work, but small expense.
You could try using aluminum solder, available at welding supply houses.
