48062
Molybdate [Texas]
March 5, 2008
For the first time in three years our WWT department had a
violation. Oddly enough it was for Molybdate. Doing some research on
this really doesn't show any other companies with that problem at the
moment. Moly being a normal replacement in steel I just found it odd
that no other area had any trouble with it.
Justin Ater
Lead Chemical Technician - Dallas, Texas, USA
March 5, 2008
This is indeed unusual, so I'm a bit out of my depth also. But I
think the molybdenum may or may not be coming from stainless steel,
but you also need a chelator like ethylene diamine in your process
chemistry in order to form a molybdate.
You haven't told us what your shop does, or what the molybdate
limit is, and I think that information would be helpful.
finishing.com
Brick, New Jersey
March 7, 2008
Justin,
You do not mention the types of processes that create the effluent
for your WWT. This may be important. As an example - if you were
doing zinc plating and black chromate and switched to a trivalent
black or changed vendors of trivalent black, you may now be using a
product which could contain a molybdate (ammonium, potassium, sodium,
etc) in addition to the trivalent chrome salts. This may not be on
MSDS depending on the requirements of RCRA (Sections 302/303, 308)
and OSHA since I believe most moly compounds are not DOT
regulated.
To make what is becoming a long story shorter (sorry) find out what
if anything has changed that would be feeding the effluent stream. If
you seek help here, the more information you can provide, the better
the quality of help (I hope).
Gene
Gene Packman
- Great Neck, NY
March 10, 2008
Most plants aren't regulated for molybenum, so you won't find much
about discharges with it on the internet. Cooling tower corrosion
inhibitors and blackening baths are other possible source. It's
pretty hard to remove molybdates from water, because they are very
soluble.
Three facilities that I know of had to convert to zero discharge to
meet their limits. Two of these were in the lightbulb business where
they use molybdenum wire as a mandrel to wind the tungsten filiment
around, followed by dissolving away the mandrel. One was a plant that
made the wire, the other plant made light bulbs.
Lyle Kirman
water treatment systems - Cleveland, Ohio
March 17, 2008
I have had success treating molybdate by lowering the pH to 4
(using sulfuric acid), and adding ferric chloride. Keep an eye on the
pH as the ferric will lower the pH (be very diligent with the pH
control as it is extremely important). After aboy 20 minutes of
mixing, raise the pH to 7-8 and flock
Gordon Djani
- Greenville, SC, USA
