(Banner at right
cycles thru suppliers of
rhodium plating solutions
and accessories)
  48051
Rhodium Finishing methods in China
March 5, 2008
Hello,
I am in the jewellery manufacturing industry and I would like to know what is the most effective technique and solution for rhodium plating jewellery? Specifically, if anyone has knowledge about the techniques used in China?
Puja
Puja Kothari
Manufacturing manager - Mumbai, India
March 5, 2008
I seriously doubt that there is any "standard" technique and standard brand of rhodium plating solution used in China, Puja. Can you please be a little bit less vague about what you are seeking? Are you trying to find a cheaper brand of plating solution? Have you seen a particular article made in China that you are trying to duplicate? Are you encountering spots or discoloration and feel that your Chinese competitors are not? It is easy to conjecture that there are "magic bullets", but usually there aren't and it's more about sweating the details. Please get back to us with more specifics. Thanks.
finishing.com
Brick, New Jersey
March 7, 2008
Hi There,
I beleive you want to know about the chinese jewelleries looks like Rodium plated and prices are cheap, the cheap jewelleries ar platd with either white bronze or Palladium flash, and the raw jewelley itself is of good finish and the polishing method is also excellent.
Hop this helps u.......Caio
Praveen Kumar
    plating process supplier
Mumbai, India
