48047
Worse adhesion of EN after chemical
polishing C75 (high carbon steel) [Switzerland]
March 5, 2008
Hi to all !
We are facing serious problems after chemical deburring of C75 steel
parts. Unfortunately we have no current on the line, it's completely
chemical. After deburring we have 4 rinses, first one is clear but
all following ones show strong yellowish Fe(III) precipitations.
Afterwards we dip in a strong alkaline cleaner with intensive
ultrasonic in order to remove the carbon remaining on the surface.
Proper rinsing is next, followed by a short acid activation. Also in
the following rinses, we observe yellow to brownish precipitations on
the tank walls. Finally we plate 5 Micron of mid phos EN. The deposit
peels off. Other steel types work perfect, C75 without deburring step
also. We observed that adhesion improves a little bit if the EN bath
gets older (more mto). Can anybody give us a hint ? Thanks in advance
and best regards to the interested community.
Helge Schuch
engineer - Buochs, Nidwalden, Switzerland
March 6, 2008
From the info given, I think that you are having a flash rust
after the polishing tank. A rusted part will not plate well. PS,
yellow would be FeII, not III. You need to work with the Mfg. to find
out why this metal is rusting and what you can do to reduce the
effect. I will guess that you will need to raise the first rinse pH
above 7 and possibly add some sodium glutanate or similar material to
prevent the rust.Your chemical debur vendor should have the answer to
this.
You may have to use a stronger acid etch before plate. I would try to
use warm rinses and would add a little ammonia to the final rinse
before EN--Get it up to the 6-7-8 pH range. This will also help the
EN kick off which may help.
- FL
March 7, 2008
Surely sounds like a smut problem to me. If possible, try cleaning
a part manually after the deburr cycle and after the activation, like
scrubbing it with a piece of scotch-brite. Then see what happens with
the adhesion of the plate on the scrubbed area.
Guillermo Marrufo
Monterrey, NL, Mexico
March 30, 2008
Hi to all, thanks for the friendly answers and good ideas. Indeed
it was a corrosion problem caused by over-active C75 steel after
chemical polishing. The material oxidised already in the cold rinses
before EN. Problem was solved by making up a special (weak acidic)
predip including some Hypo: using this solution as final activation
we can directly immerse into EN without need of additional rinsing.
Adhesion is nearly perfect now. Thanks again and have a good time...
Helge
Helge Schuch
- Switzerland
