48044
Removal of copper plating from zinc and/or
lead [Connecticut]
March 5, 2008
I would like to know if there is a way to remove copper plating
from a zinc item. I have a customer that has these copper figurines
that I believe are made of zinc. Areas of the copper are missing and
corosion has occured. He would like to have them copper plated again
but i'm guessing the zinc was not properly cleaned before the copper
plating was done. How can this copper plating be removed without
disturbing the zinc. I see that all the acids I know of eat away zinc
faster than copper. What would be the best solution? Thanks. Ron
Ron Kornacki
Powder Coating Shop Owner - Rocky Hill, CT
March 24, 2008
Just a follow up. I was searching the internet and found that
possibly using Nitrous Acid would work. Will it? I'm not sure exactly
what it is or how it would be used. Thanks in advance for any help.
Ron
Ron Kornacki
- Rocky Hill, CT
First of two simultaneous responses -- March 28, 2008
Can you not re-plate the whole part? I have polished and chromed
zinc parts leaving what remains of the old copper in place;
re-coppering then chrome plating.
Andrew Burt
Plating shop employee - Worcester England
Second of two simultaneous responses -- March 31, 2008
Perhaps a possible way would be to glass bead blast them with
care.
Guillermo Marrufo
Monterrey, NL, Mexico
