47086
Au Plating with Dry Film
[Singapore]
November 19, 2007
Hi All,
Currently I am encountering this problem:
My product requires me to do Pattern Au Plating first , followed by
Ni Pattern Plating.
Both the Au & Ni share the same pattern.
However, the headache problem is that the Dry Film doesn't really
hold after Au Plating.
Sometimes, it will peel off from the board; while sometimes, it will
have seepage.
May I request any good suggestion to make this dry film stand as it
is from the beginning till end of the process?
Eve Wong
Product Engineer - Singapore
First of two simultaneous responses -- November 22, 2007
Eve
Probably the most important things to control for good adhesion are
pre-cleaning the substrate and correct exposure of the resist.
Exposure is very important. If you are using a negative resist, it is
common to cross link the polymer sufficiently to get what looks like
a good image but it is not strong enough to stand plating conditions.
If you do not have a method of control, ask your resist supplier
about an exposure step wedge.
Second of two simultaneous responses -- November 23, 2007
Try flood exposing the boards after developing the patterns and
prior to your plating process. This works with many negative
photosensitive resists in increasing their durabilty during
subsequent processing.
Kevin Dowhower
- Lompoc, CA, USA
