47085
Chroming Defects [Malaysia]
November 19, 2007
I'm an ISO Coordinator in this company the producing knitting
parts. I am handling quality improvement program at which currently
working to reduce the defects in chroming process.
We're having a problem that is called white head - white color
appears at the top of the part after chroming.For me I believe it
would not come from the setting of the parts in the chroming clamps
or jigs. It may be caused by the setting of Voltage/Ampere/Chroming
time.
What do you think it the cause of this white color?
Uzaimi Musa
ISO Coordinator - Klang, Selangor, Malaysia
November 20, 2007
Hi, Uzaimi. You call it "white head", but others might call it
whitewash, or burning, or something else. We just don't have enough
to go on. Is this a hard chroming process? Have you successfully
plated them in the past? Can you send a picture?
finishing.com
Brick, New Jersey
December 23, 2007
Plz reduce ur bath temp. & maintain it upto 56 - 60*c. reduce
the current & increase the time in appropriate retio.
Yudhbeer Singh & Kuldeep
Kuldeep Singh
- Pantnagr , Uttrakhand (INDIA)
February 6, 2008
How many mg copper per 1000 amp/hr emission?
POPAT PATEL
- Roseville, MI
March 16, 2008
Hi , if the parts are bright nickel , them flash chrome for a
decorative finish , then the white marks could be caused by a break
of contact of power during the flash chrome cycle , or burnt , or
even because the chrome is too cold .
If the parts are hard chrome plated , you can sometimes get the white
marks due to poor jigging contact - too much heat being generated at
the point where the jig and component meet .
J Smith
- Essex, England
