47083
PEEL OFF IN CHROME PLATING
November 20, 2007
We are facing peel off problem & crack mark problem in our
plastic part (material - ABS) which was chrome plated. May we know
what is the reason behind that?
V.Veerasubramany
- Chennai, Tamilnadu & India
November 20, 2007
Thank you for visiting finishing.com, Veerasubramany, but chrome
plating of plastic is a complicated process and we'd need a lot more
information before we could even begin to try to help. Your question
is not a lot different from saying you attempted brain surgery and
are asking why the patient died :-)
Is the chrome peeling, or the nickel, or the copper, or the
electroless nickel? Likewise what is cracking? What preplate cycle
are you running? Have these parts been successfully plated in the
past? Is the problem on every part or on one part in ten thousand?
finishing.com
Brick, New Jersey
November 21, 2007
Sorry, Forgive me. Now our problem is, we have a plastic part (ABS
material) which was chrome plated. The plating procedure is first
copper, then nickel & then finally chromium. Now we are facing
some issues like peel off, crack mark (some line marks was observed)
and bubbles in the surface area of the part.
May we know what the reason behind that is? Waiting for your
reply. Thanks in advance.
V.Veerasubramany
November 25, 2007
If all of the layers are peeling off, it sounds like your etching
process is not working properly and the plating is not getting a good
tooth or key on the plastic. This needs to be solved before looking
at the cracking. Good luck.
 Ted Mooney, P.E. finishing.com Brick, New Jersey
