47082
Need to keep an ungalvanized area on parts
[Turkey]
November 19, 2007
Dear Sir/Madam
I am working for Spanish Solar System Supplier at the moment.There
are some parts.The people say that,"there souldn't be galvanizing
here". I have painted these parts for obtaining ungalvanized parts.
As I know that,polymer based materials are inreactive for HDG.
However, I saw some parts were galvanized locally. How can I prevent
this situation? Are there any special chemicals and/or materials for
not coating? Can you suggest anything?
Thanks...
Kindly regards
HAKAN ESEN
Plant&Galvanizing Manager-Material Engineer(BSc.) - Bursa,
Turkiye
November 23, 2007
I have tried for years to find something to "mask" galvanizing -
without reliable success.
In hot rolled steel, where there is plenty of millscale present, its
possible to paint with a solvent based paint, and this prevents the
acid cleaning the millscale. Where the steel isn't free of oxides, it
doesn't galvanize. So where you paint, doesn't galvanize.
But this isn't 100% reliable.
Where the steel is very rusty, its a similar thing. Paint prevents
cleaning which prevents galvanizing. Again NOT 100%.
Where the steel is not rusty and has no millscale (like fresh cold
rolled for example), its nearly impossible.
There are a whole range of proprietry branded masking systems. I have
not found a reliable one.
If you find a reliable technique, let us all know!!
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
November 26, 2007
I don't know but copper plating works fine as a stop-off barrier
in carburizing. Maybe someone else knows if it works as masking for
galvanization too.
Guillermo Marrufo
Monterrey, NL, Mexico
December 2, 2007
Sirs:
Copper plating does not work.
The information on masking that you seek is on pages 91-94 in:
"INTERGALVA 76" Edited Proceedings 11th International Galvanizing
Conference, Madrid 1976, Edited by the Zinc Development Association,
34 Berkeley Square, London W1X 6AJ, Published by PORTCULLIS PRESS
LTD., Queensway House, 2 Queensway, Redhill, Surrey RH1 1QS.
Likely you can get a copy of this article from the Zinc Development
Association or by interlibrary loan from a large, or university
library.
Dr. Thomas H. Cook
- Hot Springs, South Dakota, USA
