November 20, 2007
I want to use a gasket Sealer to seal an aluminium gasket
between an aluminium head and cast iron block. the Gasket
Sealer contains brass as its active component.
Will this be fine or is there a chance of Galvanic
corrosion? Once the gasket is in place likelihood of
exposure to moisture is extremely low.
Clinton Palmer
Manufacturer - Johannesburg, South Africa
June 20, 2008
Hi, Clinton. I'm not experienced in gasket seealant
technology, but unless the mmanufacturers instructions say
it is okay for aluminum I would be concerned about that.
Copper/brass seems to have a great capacity to cause
aluminum to galvanically pit in many applications and I
can't see offhand where this is different. Good luck.
finishing.com
Brick, New Jersey
