47076
Cobalt Electrowinning Precipitate [South
Africa]
November 20, 2007
Hi,
I'm attempting to electrowin Cobalt from a HCl / Cobalt Chloride
leach solution. At the moment this is on a laboratory scale with a
view to scaling up depending on the results.
Concentration of Cobalt in solution is approximately 60 g/l and pH
<1.
I initially tried to use a Titanium anode but experienced some
passivation effects within minutes of starting (Cobalt oxyhydroxide
perhaps?).
I've since used a Titanium anode (Iridium Oxide coated) and a
Stainless Steel cathode. Whilst I have managed to plate Cobalt to the
cathode, I'm witnessing a white precipitate forming in the bottom of
the tank (small scale approx 10 litres) and the pH is rising to
4.
The plating has formed primarily at the edges and corners of the
cathode and is very dendritic in nature. I think my current density
may be too high (50 A/dm2) but I'm not sure as I have been told that
Cobalt plating can be dendritic regardless. I reduced the current
density to 8 A/dm2 but the dendritic plating is still forming at the
edges.
I have 2 questions.
1. Can anybody help me on the formation of the white precipitate
during plating.
2. How can I avoid the dendritic plating formation.
AOG
Adam O'Grady
Chem Engineer - Johannesburg, South Africa
November 20, 2007
Hello Adam,
Divalent cobalt ions are oxidized forming cobalt (III) oxyhydroxide
anode scale - yep, you are right. Sounds like you are using the right
anodes. Are they bagged and the anodes cleaned frequently? This will
help you with the precipitate formation, and dangerous gas evolution.
As far as the dendrites, the CD may have to be lowered even more.
Good Luck!
Mark Baker
Process Engineer - Syracuse, NY, USA
November 22, 2007
Thanks Mark.
I've been finding it difficult to control the current density with
such small electrodes. I'm arranging larger ones and this should make
things easier.
I do not have the anodes bagged, but will look into this straight
away.
Thanks again.
Adam
Adam O'Grady
- Jo'burg, South Africa
