47072
Size limitations for anodized parts? [New York]
November 18, 2007
I am designing the roof of a building that will be assembled from shop-fabricated assemblies consisting of a welded aluminum structural frame (6061-T6) which is glazed using Dow silicone sealant. The aluminum must be anodised or powder coated in order to ensure adhesion of the silicone. Presumably the assembly must be anodized or coated after fabrication because the parts will be welded together. Are there size limitations for anodized items? The assembly will be approx. 10 feet long x 4 feet wide x 15 inches deep.
Roger Cumming
Architect - New York, NY
First of three simultaneous responses -- November 19, 2007
There are no size limitations. It's just a matter of finding a shop with large enough tanks. Your parts are not especially large.
- Spartanburg, SC, USA
Second of three simultaneous responses -- November 19, 2007
There are many job shops in New York State with tanks large enough to take the size you posted.
The only limitation is the size of the tanks, rectifier, and chiller that the anodizer has invested in. Lockheed-Georgia had tanks 80 feet long.
For best quality, all welded assemblies should be of the same alloy.
Garner, NC, USA
Editor's note:
   Mr. Probert is the
   author of
Aluminum How-To
Third of three simultaneous responses -- November 20, 2007
Roger,
The only limitation is finding someone with an anodising bath large enough to take your parts. You'll just have to ring round your local suppliers and see if anyone has anything large enough. I'm sure you will find someone but it may mean shipping it a few miles (unless you are really lucky and find one on your doorstep).
Brian Terry
November 21, 2007
Talk to David Kraft at Anacote in Long Island City. Right across the East River from you, and one of the best job shops around.
Dave Wichern
- Bronx, NY, USA
