Use of SUS430 in coastal areas [Saudi Arabia]November 13, 2007 Is it alright to use SUS430 in coastal areas, our building is two
kilometers away form sea. Nizar Ahmed
January 2, 2008 Neither of these grades of steel (430 or 304) will stand up to
salt spray. Even two miles from the sea you could have some salt
spray if the prevailing winds are wrong, but it should be okay if
this is "indoors" in a hallway. If this is the case either grade
should work okay.
Save
