47051
White crystals in copper plating tank [New
York]
November 16, 2007
White crystals form at the bottom of our copper preplate tank. Do
you have any suggestions to correct problem?
Bob Ross
Shop employee - New York, USA
First of three simultaneous responses -- November 17, 2007
"Pre-plate tank?" You mean, a cyanide copper strike?
Sounds like sodium carbonate, esp. if you're seeing them in
conjunction with the low temperatures we've been having around here
lately. You could see if the crystals dissolve in plain DI water;
and, if so, if the solution turns milky on the addition of calcium
chloride solution, or lime water.
If it is carbonate, just remove the solids. Best idea: REALLY chill
the tank by adding some bags of ice, or with some kind of chiller
unit, and get as much out as possible. If your carbonates are that
high you are not far from some kind of problem.
Dave Wichern
- Bronx, NY, USA
Second of three simultaneous responses -- November 17, 2007
What is your process and what is the bath composition supposed to
be?
R&D practical scientist - UK
Third of three simultaneous responses -- November 18, 2007
The white crystals at the bottom of your copper tank could be
several things. They could be undissolved salts, carbonates, a
product of a reaction with drag in, etc. Please describe what the pre
plate is: a plate or a strike. I am presuming it is a cyanide bath.
State what the chemical compostition is (or should be) and your
operating temperature. Is it a barrel or rack tank. Are you using any
agitation.
It really is necessary to have some facts to try to give an answer
that has any validity.
Gene Packman
- Great Neck, NY
