![]() (Cycles thru suppliers) |
Chromate conversion on cadmium not adhering [New York]November 14, 2007 We have a steel stamping that is cad plated with chromate
conversion- it is then painted Joe Arnold
November 17, 2007 I don't think you can troubleshoot this problem from your position or we from ours, Joe. You need to make contact with the plating shop and have them figure out what's wrong. It could be excessive brightener, and the next batch could be fine; it could be an unsatisfactory attempt to substitute trivalent chromating. Too many possibilities, I think :-)
First of three simultaneous responses -- November 17, 2007 I've seen problems like this arise both from excessive brightener,
as Ted suggests, and from poor post plate rinsing.
Second of three simultaneous responses -- November 18, 2007 Joe - Falconer isn't all the far from Syracuse where my shop is located. It would be a whole lot easier to see the actual hardware that is exhiting the problem (if at all possible before and after painting). I'd be willing to do so if you're willing to send in a couple of parts to review. People like to point their finger at the plater, but contamination post-plating is a likely cause as well. Have you gotten good parts in the past? Have you changed painting houses? How long was the lag between plating and painting? Do the parts require embrittlement baking between plating and chromating? There's a lot more to solving this issue than "why is the paint coming off?"
Third of three simultaneous responses -- November 18, 2007 Ted, Gene Packman
November 18, 2007 No, I haven't heard of a trivalent chromate designed for cadmium, Gene; I guess I was suggesting the possibility that perhaps the plating shop is trying to apply a trivalent chromate to cadmium that wasn't meant for cad and that's why it's not adhering :-)
December 1, 2007 I think there is no need to chromate at all if a topcoat of powder
or paint is bieng used. Cadmium is used because it forms its own
oxide topcoat which retards furthur corrosion, unlike zinc that
corrodes away.
Save
