47025
Is "pre heating" essential for
powdercoating? [England]
November 13, 2007
Hi there,
I'm setting a new plant with iron phosphate dip, which is then
polyester powdered coated
I'm used to pre heating my work to ensure even cure, any gassing,
thicker powder topcoat.
Will I still need to preheat?
My product is multi thickness steels ranging from 1mm-5mm thick, its
situated outside and open to the elements would you recommend a zick
rich primer process also.
I need my product to last and long term paint finish is essential,
please please advise me on how to accomplish this.
Many thanks
Carl (a worried manufacturer)
Carl Ordidge
Buyer, designer. - Warwick, England
November 17, 2007
For external uses, steel that is powdercoated only will, not last
very well.
And Iron phosphate seems the lowest possible pretreatment to
use!
For long lasting in an outdoor environment you should consider to
galvanize and then polyester powdercoat.
But this requires a competent pretreatment (Iron phosphate won't do,
Zinc phosphate, chromate, or silane are suitable).
PC only will end up like all the cheap imported steelwork that you
can see outdoors rusting away, powder peeling off, looking really sad
after even some months only.
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
November 29, 2007
Carl,
I personally believe that iron phosphate is the most widely used type
pretreatment in the world. Iron phosphate does a good job and is fair
priced. This is a good combination, however, you have to use the
proper pretreatment for the end use. Powder coat can fail if the
pretreatment is not controlled. If you have heavily soiled wash tanks
or improper ph's, or improper dwell times, you will not have an
appropriate surface in which to apply the topcoat. If this happens,
the topcoat and it's performance will suffer.
Generally, most comapanies do not pre-heat the susbstrate because you
get very uneven topcoats and you use way too much powder. When you
use too much powder, you violate the powder manufacturers
specifications to get the ultimate topcoat performane and cosmetics.
Usually the reason for pre-heat is to get powder applied into
recessed areas that are difficult to get powder into, or on MDF board
where pre-heat is required.
If you control your pretreatment, and use the correct powder for the
end use, you will get exceptional results. The important thing is to
get the powder to adhere to the substrate which really means your
iron phosphate. It's only as good as your pretreatment. If you use
tap water for a final rinse and it has alot of high solids in it,
your topcoat performance will also suffer. I could go on forever, but
you get the messege.
