47017
Chemical to remove burn marks from stainless steel?
November 10, 2007
I work for a tanker company my name is Bill, and want to know what I can use to remove the burn marks from welding I need to find a chemical to use it must look like it was not touched .
My boss is having me use a flapper wheel but I know that there is something that I can wipe it off with please if you can help thanks
William Knoche
welder - Lemoyne, PA, USA
^-- I want to contact this person and my company is a supporting advertiser of finishing.com
November 26, 2007
William:
Typical weld paste for pickling of welds will remove the heat effected discoloration (heat tint) that you see. It is generally a blend of nitric and hydrofluoric acid in a gelled solution. After removal of the heat tint, passivation should be performed with eithor nitric or citric acid gel passivation. These solutions can be purchased from a number of suppliers or contact me for assistance.
Daryl L. Roll
Astro Pak Corporation
Costa Mesa, CA, USA
July 16, 2008 -- posted here by editor in lieu of spawning a duplicative thread
how do i get rid of burnt stains left behind on a welded stainless steel
nathaniel oitomen
am a fabricator - benin, edo state, nigeria
