47007
Chrome discoloration on cycle accessories
[New Jersey]
November 13, 2007
Several chrome acessories on my motorcycle have begun to
get a hazey goldish discolored areas (mainly on flat
surfaces)The items are only 12 to 18 months old and have
been well taken care of( cleaned / waxed etc.)and the
vehicle is garage kept.This discoloration seems to be
escalating more rapidly. what can I do to restore the finish
and prevent the spread of it?
Jim Bogle
customer - Hillsdale, NJ, USA
November 13, 2007
Chrome should not discolor except possibly due to extreme
heat (exhaust pipes), Jim. Are you sure these components are
actually chrome plated rather than just something shiney?
finishing.com
Brick, New Jersey
November 14, 2007
Yes it is chrome, this is the retailers
description:
Baron's BAK is the hottest RoadStar
accessory on the market. Your bike will rev quicker, pull
harder and have a noticeable increase in overall power. Each
cover is precision-milled, highly polished and bathed in a
show chrome finish. Each BAK comes with a complete Jet Kit
for accurate tuning of your carburetor. Kit includes Billet
Air Cleaner Assembly with K&N; filter, plus the performance
Needle/jet kit consisting of Baron's specially designed
titaniun adjustable needle, Mikuni main jet, and all
necessary hardware. The BAK also includes the PowerCone and
the RainCoat. All you need in one convenient
package!
another problem area is the handlebar risers.........I
believe they are chromed steel.
JIM BOGLE
- Hillsdale, N.J.
November 15, 2007
Jeffrey Holmes had suggested on a somewhat similar letter that the
yellowed areas may lack chrome plating, and the underlying nickel is
tarnishing -- this sounds possible, I guess. Metal polish and
frequent waxing are the only defense against the yellowing if chrome
is missing.
 Ted Mooney, P.E. finishing.com Brick, New Jersey
November 23, 2007
You are seeing the nickel that was under the chrome. You said the
areas of tarnishing seem to be getting larger. You also said you
clean and polish your chrome regularly. In some circumstances I have
seen parts that were cleaned and polished so much that they rubbed
right through the chrome. Good chrome should never need polishing.
Just a gentle wash with soapy water or glass cleaner followed by
waxing. If you use something that says it is a polish, it will most
likely be too abrasive. Every time you polish your part more chrome
is removed and more nickel is exposed.
There is the possibility that you may not have gotten good chrome in
the first place. Lately I have had more customers bringing me parts
that seem to have suffered the same fate. These parts are mass
produced which makes them inexpensive but sometimes quality suffers.
And, of course, they will never compare to items that are custom
plated at a good chrome shop.
If you want parts that are more durable and better looking, take them
to a quality custom plating shop that has a good reputation. You will
pay more but have fewer regrets down the line.
