47006
Antiquing copper accents on cedar coffee
table without affecting cedar [California]
November 13, 2007
Hi All,
I am building an artistic but functional outdoor coffee
table out of cedar that has lots of copper inlays. Cedar
table will be varathaned to protect it and then copper
accents will be nailed to it using copper nails. I would
then like to antique the copper to a brownish black aged
look. How can this be done without affecting the wood if the
solution gets on the wood? Also how can the copper then be
protected so it can be used as a functional coffee table,
ie: objects being placed on it without scuffing the patina,
while preferably not having to mask the whole wood section,
there will be lots of copper and not in straight
patterns.
Kevin Coulter
Hobbyist - Kagel Canyon, CA, USA
First of two simultaneous responses -- November 13, 2007
I am probably missing something here, but antique the
copper and the nails before they are inlayed and after the
first coat of varthane and then add the second and third
coats of varthane. Note that the varthane will yellow in
sunlight and with time.
- FL
Second of two simultaneous responses -- November 13, 2007
Hi Kevin,
Once you have the copper looking the way you want, apply a
couple coats of my protectant and you'll be good to go for
several years at a time.
November 16, 2007
I don't want to pretreat the copper because I feel with all the
hammering of the nails it will ruin the finish. One option I guess is
to apply a brown/black patina after the copper has been inlaid and do
it carefully, or possible use a black wax to achieve the effect.
Don't want to varathane the copper either as it will show somewhat
yellowish and chip off over time. The Shark solution should get me
around that problem, so its just a matter of the best way to antique
the copper once inlaid on the wood. Any more ideas would be
appreciated, I will try and attach a sample pic to show what I am
trying to duplicate.
Kevin Coulter
December 12, 2007
Kevin, your on the right path about applying a patina after
installation of the parts. We can set you up with the right patina
which can apply with a q-tip or sponge to get the effect you want.
Best
