47003
24 ga. tin plated copper wire is arcing the
hard chromed surface of a ring [Ohio]
November 12, 2007
I am hard chrome plating the outside diameter of some wire spools
that 24 ga. tin plated copper wire is riding on. During this process,
the wire will be annealed on the ring using current that is charged
to the ring. I am uncertain of the amount of current to the ring. We
have coated many rings with electroless nickel and the rates have
reached 40,000,000 - 50,000,000 conductor feet. The rings that were
hard chromed had only reached (best case) 17,000,000 conductor feet
(worst case) 3,700,000 conductor feet. My question is to know why the
arcing is more present with the hard chrome plating and the
elctroless nickel is successful ? We are trying to experiment to
exceed our footage even with the electroless nickel. The base
material of the rings are mild steel. The customer calls for a
polished surface after plating. Any help is appreciated. Thank you in
advance, Mike Deye.
Mike Deye
Plating Shop Employee - Toledo, OH, USA
November 13, 2007
I would go with hardened steel that is ground and polished and
then EN coated to 0.0015 per side and then baked to harden the EN.
- FL
