PVC Tank Linings for 85 °C. use?
goadbanner4
RFQ: I am seeking PVC lining material for finishing baths, withstanding temperature up to 85 °C.
Needed quantity is approx. 500 square meters. Please advise, thank you. Yours,
Osama Suliman
- Khartoum Sudan
A. Hello Osama. The upper temperature limit for conventional flexible PVC tank linings is not more than 65 °C, and some people advise not using it above 60 °C. Conventional flexible PVC is not an appropriate tank lining material for this temperature.
If you can provide provide additional detail about what kind of "finishing bath" you have in mind, our highly experienced readers will probably be happy to suggest alternate construction materials and methods.
A. We are using a fiber reinforced tank lining for our hard chrome plating tanks, called "Fiberliner". It has very good adhesion and can meet your temperature needs. It should last for 10-15 years on a chrome plating tank. The lining was provided by Innoplate International in The Netherlands. Call these guys, maybe this lining can help you. Sincerely
Tim Jaarsma
- Hengelo, The Netherlands
Ed. note: We appreciate the effort to help but, in the end, brand name or sourcing suggestions have proven to do more harm than good ( huh? why?)
A. O. Suliman, the best application is to use CPVC Sheet dado'd glued and welded. If the tank is longer than 3-4 m then use 1/2" material. Allow 3/8" growth on the length.
skip schaefer
- Pomona, California
A. We are a plastic tank manufacturer with expertise in polyethylene, PVC, CPVC, Polypropylene, and other specialty plastics. We have tanks and liners operating well above 85 degree C. All of our equipment is mill duty use withstanding chemicals ranging from HF, HCl, H2SO4. For more information, visit our web site at [deleted by editor]
Eric MacDonald
- Pittsburgh, Pennsylvania, USA
Ed. note: We appreciate the effort to help but, in the end, brand name or sourcing suggestions in forum postings have proven to do far more harm than good for a long list of reasons ( huh? why?)
Readers may be interested in these related threads:
Topic #42796 "Tank & lining material for chrome plating and chromic acid Q&A"
Topic #5843 "Leakage problem in PVC lined Chrome plating tank"
Topic #61492 "Best way to remove lining from Chrome tank"
Topic #35118 "Polypropylene Compatibility With Chromic Acid Solutions"
