Method for analysing Zn in rainwater
Q. Anyone know a simple method for analyzing for Zn and ammonia in rainwater runoff from a galvanizing plant site?
In the UK it might become necessary to collect runoff water and treat it to remove Zn and ammonia before it hits the storm water system.
Need to analyse the water to see what the current "contamination" level is.
Seeking a simple method for "bucket chemists" (titration?) as galvanizing plants typically don't have an AA, OES XRF etc.
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
"Colorimetric Analysis of Metal Finishing & Metal Working Solutions & Effluents" by Aubrey Knowles on AbeBooks or Amazon (affil links) You will not be able to titrate the zinc. You will be interested in concentrations that are far too dilute for that. In rainwater, they will likely require effluents to be less than 0.05 ppm. You really want an AA for this. If you already have a spectrophotometer, you should also have Aubrey Knowles book "Colorimetric Analysis of Metal Finishing & Metal Working Solutions and Effluents" ⇨ Jon Barrows, MSF, EHSSC GOAD Company Independence, Missouri 2007 2007 Try Hach's "Zincon" method. I used to use it as a go/no go indicator for wastewater to be released. Dave Wichern Consultant - The Bronx, New York |
