What makes some brass magnetic?
Q. I have been collecting brass from thrift stores, and always check it with a magnet. I can easily tell brass plated items from solid brass this way. However, some items, although marked "Made in India" as much brass is, and looking just like solid brass, show a very slight_ attraction to a magnet. Is there an alloy of brass that contains iron?
Dave BlanchardHobbyist - Portland, Oregon, USA
A. Brass is non magnetic.
The items you have bought are probably brass plated mild steel. It is quite common.
A. Iron melts at 1538 °C. Bronze under 1000 °C depending on its alloy. So, iron is not considered an alloy for any bronze but rather a contamination; in my opinion, not enough to attract a magnet ... unless it is added intentionally for cost reduction purposes.
Guillermo Marrufo-Mexico
Monterrey, NL, Mexico
A. Geoff is right, there is loads of brass plated steel goods around, so beware.
There won't be enough Iron (if any) in brass (which is a copper/zinc alloy) to be magnetic, but in what we in the UK call Nickel Aluminium Bronze (might also be called Aluminium Bronze) there is about 4.5% each of Iron and Nickel; this makes it a bit magnetic.
It is however unlikely that your brass items are of this more specialised high strength alloy.
Ship Repair - Plymouth, UK
A. There's also a possibility that some 00 steel wool [on
Amazon (adv.)], filings, powder or wire was added in the mold before pouring the bronze. That would make it somewhat magnetic and less expensive to produce.
G. Marrufo
Q. I have a brass looking item that is very slightly magnetic with a powerful rare earth magnet and reacts vigorously with nitric acid. I thought it might contain nickel which is one of only four magnetic metallic elements but it doesn't react with acid. Maybe that aforementioned aluminum bronze. I will XRF it next week.
ken mason- weimar, California usa
October 28, 2017
! I want see that promised XRF! I too have a pair of Pakistan brass candlesticks. One is non-magnetic, the second of the matched pair does attract a rare earth hard disk drive magnet.
Robert P SchlemmerChemical Company - KSA - Kuala Lumpur Malaysia
July 27, 2018
