How to remove silica scale from faucets, etc.
Q. I am looking for a non-abrasive method to remove silica build up on faucets, shower heads, etc.?
The white buildup I am talking about is on the plastic shower nozzle and the interior glass surfaces of the shower stall. Our water analysis shows high concentrations of silica. Is there a chemical approach to remove this type of scale?
Mark Schanfein [returning]
- Los Alamos, New Mexico, USA
A. Just because the water has a high silica content, does that necessarily mean the deposits are silica? Maybe it's just soap scum that will come off with an alkaline cleaner?
Bill Reynolds
Bill Reynolds [deceased]
A. You might try cleaning it with a solution of 2-4 tablespoons of bicarb of soda in hot water, followed by a rinse followed by straight white vinegar [in bulk on eBay or Amazon (adv.)] (acetic acid [on eBay or Amazon (adv.)] 5%) works on carbonate scale but NOT on silicate; full stop, end of story.
Mild solutions containing hydrofluoric acid (HF) are the only solution to silicates scale. WHY? Because it's the same acid that's used to etch glass (Silica). Agree with previous comments; please be exceedingly careful with any solution that contains HF. I would advise:
1. Please read up as much as you can prior to use.
2. Don't get it on glass; it will etch the glass very quickly and permanently.
3. Only use where you can control the run off drips & splashes 100.00% to ensure that the acid is completely washed away at the end of the treatment.
4. Calcium Gluconate gel is the antidote for skin contact after immediate washing with water.
5. Serious contact WILL REQUIRE hospital treatment.
Now if you still want to do this you can find many HF containing cleaning solutions in aluminium mag wheel cleaners as manufacturers use sulfurIC ACID mixed with SODIUM HEXAFLUORIDE to make HF in the mixture but don't have to declare it on the label as they never added it into the product.
OK, last bit of advice : consider very carefully the potential of this to go wrong and the cost of a new shower head.
Anthony Symons
Integrated Hygiene Management - Lawson Blue Mountains Australia
A. It is looking like Australia is way ahead of good old USA.
Forget the C-L-R, the bicarb and lemon juice and contact Gell Enterprises Inc., Fresno California. They sell, AMAZ, a product that will solve your hard lime scale problems. I have been using this professionally for several years now.
AMAZ is produced in the USA so you should not have a problem in locating.
Paul Mitchell
Alpine Carpet & Tile Cleaning - Banksia Grove Perth, Western Australia
June 29, 2017
Ed. note: We tone down commercial testimonials for a number of reasons, including the fact that we don't know the vested interests of the responders. But even still, since we never hear from company lawyers when their product is praised, but have heard from them quite a number of times when their product is dissed, it should be recognized that reviews you read on websites like this tend to be unrealistically favorable rather than properly balanced :-)
Removing lime scale from plugged nozzles
Q. My client uses hard water in the 7-stage washer for cleaning 2-piece tin-plate steel
food cans. Stages 1 and 2 run at temperatures at 130 - 150 °F. They get lime scale buildup on the nozzles and in the risers. Any suggestions to easily remove the scale from the steel nozzles and steel risers in the washers?
Frank McDonough
scientist - Collegeville, Pennsylvania
November 10, 2017
A. Hi Frank. Commercial products like CLR and Lime-Away are basically for this purpose; I don't think we'll come up with a home-brew which is better. But if the problem is too severe to deal with, it may be necessary to start with softened or DI water and/or to make up the cleaning solutions from potassium-based chemicals or at least sodium-based and avoid calcium. Good luck.
pic of Ted Mooney
November 2017
Q. A mild hydrofluoric acid solution has been mentioned for removal of silica deposits on ceramic/porcelain toilets and sinks. Is it safe for use on:
1) chrome fixtures
2) satin nickel fixtures
3) stainless steel kitchen sinks
4) fiberglass tubs and showers?
Shirley Tyler
- Underwood, Washington, USA
August 21, 2019
A. Hi Shirley. It's not safe for people, that's for sure.
It's not safe on 1) or 2). It's not 'good' for 3) but may not harm it if rinsed well. HF eats glass, so it's not quite 'safe' on fiberglass. But as long as it's not old and wicking, or has a gel coat on it, it's probably okay.
pic of Ted Mooney
August 2019
thumbs up sign Thank you for responding to my questions. That was very helpful.
Shirley Tyler [returning]
August 24, 2019
November 13, 2019
Electronic Descaler
on
Q. Hello.
I would like to know if the electronic descalers on the market (like ScaleBlaster, Eddy, etc.) work on silica.
A product called ScalePro says that their descaler does work on silica.
John Benton
- Richmond, Virginia USA
December 2019
Electronic Descaler
on
A. Hi John. Sorry, we can print general responses about electronic descalers but not responses about ScalePro's claim. This is a "no-registration required" website where we have no proof that anyone is who they say they are and is without vested interests. We've had several suppliers pose as 'satisfied customers' (we knew because the poster's IP address was the same as the vendor's website). Similarly we might be sued if we printed a response that says it doesn't work because we have no guarantee the posting wasn't brand assassination by a competitor :-)
In short it's best to use this site for technical issues; we'll leave reviews to "registration required" sites like Amazon
pic of Ted Mooney
