How to make a water solution of zinc phosphate
Hi,
I need to dissove a technical powder of zinc phosphate (45% zinc). I made the first dilutions in HCl acid, which seems to work fine. But as soon as I add distilled water to make a further dilution, the zinc percipitate. I need to keep the zinc in solution.
any ideas?
Adel Jacobs
laboratory analyst - South Africa
What is the pH before and after dilution, Adel? The zinc cannot stay in solution if the pH approaches neutral after dilution. Good luck.
