No passwords, No popups, No cost, No AI:
we earn from 'affiliate link' purchases, making the site possible
Sound technical content, curated with aloha by
Pine Beach, NJ
  for Metal Finishing since 1989
Cadmium whiskers on Hubble
As the Materials Assurance Engineer for the Hubble Space Telescope, I have to determine whether a Cd chromate part is qualified to fly next year and then will function in LEO for 10 years.
The part is alloy steel (1.0 Mn) Cd plated with chromate conversion coating. During ground testing it will be baked at 70C for a week then maintained at RT for a year. In orbit, the operational temperature (for 10 years) will be 0C in vacuum of 10-5 Torr.
My question is, what is the probability of Cd whisker formation under these conditions?
Thanks in advance.
Benjamin Reed
- Greenbelt, Maryland
I shouldn't think that whiskers would be as much of a problem as sublimation. I have no real knowledge of the subject but have been told (see topic 20) that cadmium cannot be used in vacuum applications.
Ted is right. Cadmium does not appear to be the kind of coating I would use unless pressure surrounding the part is above at least 1 Torr as well as there is a probability of galvanic corrosion. If lubricity is not an issue, I would look at a coating such as nickel.
My guess is that cadmium will sublime in 10-5 Torr vacuum at the rate of approximately a few picogram per sq. cm. at 0 C.
Mandar Sunthankar
- Fort Collins, Colorado
Thanks for the prompt response.
I am not concerned with sublimation. At 0C the vapor pressure of Cd is off my chart but it looks to be around 10-12 or less. So my application of 10-5 or 10-6 Torr is sufficiently higher that the rate of sublimation does not concern me. It was the whiskers that I was having trouble getting a handle on.
Benjamin B. Reed
My understanding, some of which is fact and some which is probably urban legend is:
Sorry, I could not easily find any reference to genuine research into cadmium whisker growth and can only refer you to our FAQs which may flesh out some of the above and offer you additional contacts. Regards,
Why cadmium/chromate a part for orbit?
Is corrosion a problem in these conditions?
Ian Brooke
university - Glasgow, Scotland
Dear Mr. Reed:
I cannot improve on the fine responses listed above. However my response is in the form of a question. We employ Cadmium coatings as a galvanic protective layer on steel in the presence of corrosive elements and atmospheres. I am thinking that in space, we have close to a vacuum in which neither salt, nor corrosive gases will attack a plated surface. Why even consider Cadmium for the Hubble? You may wish to consider even more basic plated coatings that have been used on earlier spacecraft. Also consider that many space vehicles have components made of Titanium in which we could get toxic outgassing. This may only be a problem when the Hubble is "snagged," by the Shuttle for routine maintenance. Then, the personnel on board the shuttle may be exposed to toxic fumes.
Your question is a particularly interesting and intriguing one. I am going to be looking for additional responses on this venue.
ed budman eb sig
Ed Budman [dec]
- Pennsylvania
Background of the problem:
There is a safety requirement that no "hot" mate/demates be made during an EVA. What that means is that JSC does not want its astronauts to be exposed to the risks associated with the mating of power connectors in close proximity to their suits. However, during the next two servicing missions of the Hubble Space Telescope, its batteries need to be taken off line (replaced during the latter). Unfortunately, they do not have a simple on/off switch, so to avoid a "hot" demate (and mate) of the battery connectors, we will be flying a heavy duty switch, several actually. As with all projects, much of the design is being driven by time and money. Given limitless supplies of both, I would not be flying a Cadmium plated steel part. However, since both commodities were in short order our trade study examined just available switches which met all of the functional requirements as opposed to building and qualifying one from scratch (which is what we do most often). For example, one of the alternative switches was 20 times more expensive, had a longer lead time and would have required significantly more qual testing prior to acceptance. So that is (briefly) what led me to asking this discussion group of experts for their opinions.
Thanks again for everyone's input. BTW, I will approve the part to fly.
-Ben
Benjamin B. Reed
This is just for curiosity.
Whats Hot mate/demate, EVA & JSC?
Did you consider Ion Vapour Deposition, aluminium say?
And Ed Budman what were you saying about Toxic outgassing, other peoples work is always fasinating.
Ian
Ian Brooke
Hot mate/demate: the physical act of bringing together two halves of a powered connector, i.e., they are hot and they are being mated
EVA: Extra Vehicular Activity, space walk
JSC: Lyndon B. Johnson Space Center, Houston, Texas
We only considered the switches that were available, met the functional requirements, and were cost effective.
-Ben
Benjamin R. Reed
- Greenbelt
