Difference between depassivation and deoxidation
Q. I want to know the difference between depassivation and deoxidation because I am having a problem trying to explain to my colleague who are arguing about the difference
Mobius Shumba
Quality Assurance Officer - Harare, Zimbabwe
A. Personally, I've never had occasion to use the phrase 'depassivation' in a career of several decades in metal finishing, Mobius. The point being that, although words should have precise meanings, trying to imbue a word which is not found in a dictionary with a precise meaning which is not dependent upon application and circumstance and context, isn't working. Try to explain the context in which this argument arises and someone may be able to throw light on the situation and help you solve the problem. Good luck.
A. Mobius
The two terms can probably mean the same in certain situations.
Depassivate, to me, means to make the surface reactive. There was an earlier post where a SST part was passivated, then 'depassivated' in areas to receive a carbon nitriding process. My take on it was that having a reactive surface improved adhesion.
Deoxidizing is to remove an oxide layer, which in turn makes the surface reactive.
In plating zinc where a post-plate hydrogen embrittlement relief bake is performed, the zinc must be reactivated (it becomes passive from baking) for subsequent chromating.
Hope this helps.
Willie Alexander
- Colorado Springs, Colorado
Q. How to Depassivate High Speed Steel for Nitriding Process?
Lal B. Singh
- Newmarket, ON, Canada
October 5, 2013
A. Lal,
Seeing that high speed steel is not a class of stainless steel, I would suspect that no passivation has occurred and therefore no "depassivation" is needed.
Speaking as a chemist, I think the preferred term would be "activation" as the opposite of passive is active. "Deoxidizing" in terms of removing metal oxides from the surface also sounds acceptable. In most cases this will be the same thing as the majority of passive layers are composed of metal oxides, and removing it exposes an active surface.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
October 8, 2013
