ACID TIN SULPHATE PLATING
SOLUTION of composition tin sulphate-30 g/l, sulfuric acid-100 ml/l,
using ATOTECH brighteners but no brightness found on parts and also in the hull cell panel. What is the reason?
Aftab Jahangir
Aftab Jahangir
chemist - Karachi, Pakistan
You may keep bath temperature under 22 centigrades and brightness will appear.
Gabriel Schonwald
Bnei Berak, Israel
Aftab,
You may have a look at the ltr.No 45619 in the same forum below.It is also reg. Tin plating.
t k mohan
T.K. Mohan
ADD 10G/L TIN sulphate AND CHECK THE PLATING SOLUTION FOR CHLORIDE PRESENTS.
SHODHAN JOSHI
plating products agent - Ahemadbad, Gujarat, India
thanks all the people for good response to my letter.
but I found the brighteners were expired. I took new brighteners and found satisfactory results..
THANKS AGAIN,
Aftab Jahangir
Aftab Jahangir
