Aluminum 5052 has good corrosion resistance -- so purpose of anodizing it?
Q. If Al 5052 is considered as having good corrosion resistance, what would be the reason(s) for anodizing parts made from that alloy? Appearance only?
Zen Pinsky
Product designer - Milwaukee, Wisconsin
A. Proper anodizing may greatly improve its corrosion resistance.
Al 5052 often severely corrodes due to magnesium segregation into the grain boundaries of the alloy [5052 contains ~2.5 wt% Mg whereas the solubility limit of Mg in Al is < 1% at room temperature]. The stabilizing heat treatment used for commonly available tempers such as H34 & H36 contributes to the problem. Unless anodizing, for better corrosion resistance, use the H114 temper and avoid ever getting it much hotter than 100 °F.
Clean a sample of your 5052 and leave it in tap water. If there is excessive segregation in the alloy, 'cauliflower' corrosion nodules may sprout within a day or two.
Ken Vlach [deceased]
- Goleta, California
What is difference between 5052 H32 Temper and 5052 H114 temper
ninganray Mahadev Hirekodi
- Bangalore, India
November 14, 2014
Hi Ninganray. H32 is Strain hardened and stabilized by low temperature heating, 1/4 hard. As Ken alludes to, H114 involves strain hardening but no thermal treatment. When there are 3 digits after the H, it is a special variation often applicable to one particular shape or method.
Please try to put the question into the context of your own situation, as abstract questions have no direction to them. Thanks.
November 2014
