Step by step Alocrom
I send components out to be Alocromed on a regular basis but I am unable to see with my own eyes what the process includes as our sub contractor is a few hours drive away, please could you explain in layman's terms the step by step process involved.
Christopher Grant
Production Engineer - Tewkesbury, England
You can probably get a technical data sheet from the Alochrom supplier and it will probably mention the steps. Usually the steps are alkaline non-etch clean, rinse, etch, rinse, desmut, rinse, Alochrom, rinse. Sometimes etching is skipped, sometimes there's a double etch-desmut.
Further to Ted's response the common route (although nowhere near exclusive) for treatment for Alocrom (Alodine to the rest of the world) would be something like this:
1. Degrease (this may be a vapour-form degreasing or swabbing with non-chlorinated solvent)
2. Mild alkaline clean (this is usually a proprietary solution from one of many manufacturers)
3. Rinse
4. Etch/Deoxidise (this may be done out of either acid or alkaline solution, some deoxidisers are self de-smutting, others will require a de-smut)
5. Rinse
6. De-smut if necessary (this will depend on your etch/de-smut step)
7. Rinse
8. Alocrom to obtain the required features (whether it be coating weight, colour, corrosion resistance)
9. Rinse
10. Dry at a temperature below 50C (although I think it should be below 40C personally)
It is impossible to give times and temperatures for these processes as so many of them may be proprietary, plus I suspect your treatment house has been doing this process for a while and should have a reasonable understanding of the process.
Hope this goes some way to help give you an idea of the process.
Brian Terry
