Stripping galvanizing from a propane tank
I have a 150 gallon propane tank that is galvanized and I am trying to remove the galvanizing without damaging the tank itself too much. I have tried grinding, which works but is very slow going, and then you also have the lead dust particles to worry about. I also thought about using muriatic acid [affil links] diluted down to remove this galvanizing coat. If anyone has any suggestions it would be greatly appreciated.
Jim Whidden
architectural designer - Fort Myers, FL, United States
Muriatic acid will very quickly strip the galvanizing, although galvanizing is thick and will require a reasonable amount of muriatic acid. But it isn't clear, when you say "without damaging the tank too much", whether the tank has become just a decorative item at this point. I would not attempt to strip galvanizing from a functional tank which is or will subsequently be pressurized.
