No passwords, No popups, No cost, No AI
we earn from your eBay & Amazon purchases
curated with aloha by
- Pine Beach, NJ
  pub
  for Metal Finishing since 1989
Need help refinishing a 100ft metal dock
Help! I have an approximately 100 ft dock that is beginning to rust all over and needs refinishing this summer. It's going to require some level of scraping/grinding, to remove as much flaking paint and rust as possible, but it's not going to be possible to remove everything. It's a very daunting task. Problem is, I don't know what types of products I should be using to treat and paint the metal with. I want to do a good job so that it lasts a long time and keeping it up will be easier over time.
Does anyone know what I should be using?
Any help very much appreciated, thanks!
Pete Arduini
Hobbyist - Vancouver, BC Canada
Try to obtain Hammerite Rust Cap [affil links] paint (modified silane based product; you can paint it directly on rust). Second, cheaper option is good priming paint + several layers of topcoat paint).Hope it helps and good luck!
Hi Pete,
To add my penny's worth, there is a SHELL epoxy, EPON 828, I believe, that was designed to CURE under water incl. seawater. Maybe other epoxies are as good, but that I dinna ken.
Food fer thowt, as they say in Eton.
But epoxies (incl. polyesters, vinylesters) are relatively brittle so you'd have to use some glass cloth/matt etc.... but any good supplier would give you the know-how.
freeman newton portrait
Freeman Newton [deceased]
