Galvanised or coated iron metal gets rusty in the coastal area, like Mumbai
As I have seen many times galvanised or coated iron metal get rusty earlier than our expectation. Is there any other solution to keep away from rusty metal like water lines and different structures.
Arun Janardan Ghorpade
consumer - Navi Mumbai, Maharashtra, India
Galvanized (zinc plated by immersion in molten zinc) object must be conversion coated (chromated or phosphated or treated with some modified silane based product) and then painted. Paint only finished objects must be phosphated,or chromated,or treated with rust converter [on eBay or Amazon (adv.)] and then painted (primer +topcoat). Good luck!
You can try Dacromet 320 coating in place of Galvanizing.
Sanjay Chitlangia
- Gurgaon, India
October 2013
Hi Arun. The zinc-rich dip-spin coatings Sanjay suggested (there are many brands) might be one alternative, and there are dozens of other alternatives -- including phosphatizing and painting as suggested by Goran. Still, each technology including galvanizing has thousands of shops successfully practicing it ... and the answer to corrosion problems is usually to figure out what may be wrong rather than bounce around from one to the other, especially when galvanizing has more proven longevity in the general case than any alternative. Good luck.
