Black spots on aluminum from anodizing
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. Dear sir,
We are facing problems after Anodising: some black pits & patches, but they're not there before anodising. Please help me sir.
Employee - Chennai Tamil nadu
April 6, 2022
A. Hi Karthik!
Readers have already suggested possible porosity, poor quality castings, poor cleaning, and lack of proper de-oxidizer/desmutter as the most likely causes ... but without pictures, or a listing of your process steps, or knowing the alloy and type of parts, there probably isn't much more to say :-(
Please send pics to mooney@finishing.com along with alloy and part type, and treatment sequence. Thanks!
April 2022
April 11, 2022
Q. Dear sir,
Thanks for your reply.
We are Facing the problem for black pits found only in particular area in vision camera & boroscope inspection.
Before Anodising the part is visually inspected through cutting section & penetrant test part will be OK
But After Anodising we face that problem in particular area
Q. We do AC2A and we are doing anodizing after machining.
Anodizing process:
Temp 8 °C
sulfuric acid :150 g/litre
Precleaning : non alkaline degreasing agent
Current density 1.5A/dm2
Using distilled water with pH 6.5 ~ 7.5
TDS <30 PPM
We face a peculiar problem of black spots after anodizing on our brake parts.
Why is this happening and what could be the countermeasures?
- Chennai, Tamilnadu, India
A. Guess #1 is a porous and poor quality casting. - Navarre, Florida 2007
A. Does the spot happen on any parts you do or just only happen on a certain part? - Singapore 2007 |
A. Degreasing alone as pretreatment for anodize is totally inadequate. All aluminum alloys have a natural occurring oxide layer on them that must be removed prior to building a fresh, dense aluminum oxide (i.e. anodize) layer. These are typically acid mixtures such as nitric / bifluoride or chromic / sulfuric. Without one of these etches, deoxidizers, and / or desmutters, you'll get a patchy, non-uniform, spotted anodize!
Milt Stevenson, Jr.
Syracuse, New York
