44089
Electropolish and Bead Blast? [New
York]
February 21, 2007
We recently reviewed routing sheets for a maker of 303 stainless
steel components which are then electrodeposited with nickel plating
per QQ-N-290 [link is to spec at TechStreet] specs.
Routing sheets indicated a permaganate clean followed by an
electropolishing step and then followed by a dry glass bead
blast.
These components are seeing a high degree of plating adhesion
problems recently even with the above cleaning regime. We reviewed
other components which have similar cleaning processing/plating done
to them without any plating adhesion problems. Those components are
also made of 303 stainless.
We've went to copper strikes recently which has resulted in
components where the nickel plating adheres but it is believed at
this time that the root cause of the plating adhesion problems still
not been identified?
Removal of Nickel plating from stainless steel surface is not an
option. The engine manufacture wants the plating.
Daniel Spells
Aerospace - Buffalo, New York, USA
February 21, 2007
I may have misunderstood your question, Daniel, but it sounds like
you don't yet have any observations upon which to make a conjecture
towards root cause except that a copper strike helps. If I
understood, the parts are processed identically and the plating
adheres to some and fails to adhere to others?
QQ-N-290 says it applies to steel (and copper materials) but it
does not claim to apply to stainless steel, and I don't think it
does. I think you need to do a Wood's Nickel Strike before the copper
plating. Of course, the usual caveat applies that you can't process
real parts except per the specifications.
finishing.com Inc. - Brick,
NJ
February 21, 2007
My favorite subject, 303.
From several years in jobshop work, we rarely saw just plain 303. It
almost always had a suffix something like S or Se or ???? These make
a world of difference as it is an additive to 303 to make it "free
cutting" as in leaded brass.
That said, I have never seen such an aggressive preplate cycle.
The electropolish makes it difficult to plate because the surface is
now very passive and has oxide films. The glass bead helps to reduce
the passivation by roughing up the surface.
The solution to adhesion problems is a stronger acid activation step,
one for whatever suffix SS you are working with. You have NOT
mentioned what you are using. Without delay, go to a Woods Nickel
strike. This is not a good place for a sulfamate nickel strike which
is great in a few other places. Next is to not let the parts
repassivate between the strike and the nickel plate (it only takes
seconds). Keep the parts wet and proceed as rapidly as the line will
go.
I do not remenber any Aerospace OEM spec that allowed a copper strike
on 300 series alloy under a nickel plate.
- FL
First of two simultaneous responses -- February 25, 2007
Hi;
It is 303 SE. It is plated with a low stress sulfamate Nickel
plating. We did an SEM and found on the back of the plating (the part
of the plating that is in contact with the stainless steel) Cadmium
and Chromimum.
We have observed their processing and according to both the platters
and connector maker these connectors are the only ones that have
plating coming off. Plating a stainless steel connector with Nickel
is kind of redunant but that is what they want. The connector itself
is quald to MIL 83723/88N. That spec calls out QQ-N-290.
We have seen other parts that have everything the same (material,
plating, no copper strike) and did not observe any plating coming
off.
I am thinking it is in their cutting fluids, or pre plating
processing which is not removing something that they are putting
on.
Dan
Daniel Spells
Second of two simultaneous responses -- February 25, 2007
I'd agree with the previous two submissions adding that the
permanganate followed by electropolish pretreatment is what I would
expect for heat treated or welded stainless that has an intense blue
heat treat scale. Using an alkaline permanganate renders the blue,
acid-resistant scale removable by acid (i.e. electropolish)treating.
My firm does a ton of nickel plating on stainless, Invar, and other
nickel bearing aerospace materials such that the parts can be brazed
- we rarely encounted such adhesion woes - especially on something as
basic as 303 (S or Se) stainless! Another possibility could be the
cleaning - anodic cleaning of nickel bearing alloys can also render
the surface more passive that it would be otherwise.
April 18, 2007
Dear,
With all that cleaning and electropolishing, your are realising a
perfectly clean and smooth surface. Why are you
destroying/contaminating this smooth surface with the
glassblasting?
In my experience, an electropolished surface is a perfect base for an
electroplating.
On the other hand, the sequence and type of layers you have to apply
are very important and are the problem/answer in your situation.
Marc Quaghebeur
- Brugge, Belgium
