44080
Need MIL-DTL-16232 compliant plater ASAP!
[Michigan]
February 20, 2007
I've a job pending for the US Government for a mounting plate, low
carbon steel, approxmiately 3in x 1.5in x 1/4 thick, that requires
the heavy phosphate coat per MIL-DTL-16232 Type M -OR- Z class 3.
This is about 300 lbs worth. Here's the catch - The company must have
been approved for this process by the government before OR be willing
to accept a short inspection of their facilities. My normal suppliers
for plating have absolutely stonewalled me. I'm located in Michigan,
and therefore would be preferential to responses from the
Midwest/Northeast, but considering how hot the job is, I will take a
serious look at any inquiries anywhere in the nation. Any bidders
would definately be remembered in the future for this type of
process. Thank you in advance!
Rick Novak
Hardware Distributor - Livonia, MI, USA
